Wireless home phone outgoing volume
  • 8 December 2019
  • 1 reply
  • 90 views
Hey all,
Just received my Koodo wireless home phone and am getting it all set up. So far, call quality seems very good on my end during test calls, but people on the other end are telling me that it sounds like my microphone is maxing out. I know the incoming volume can be adjusted, but is there a way to adjust the OUTGOING volume for calls via wireless home phone? Or is it something that can’t be changed? Thanks!
1 reply
No, you can’t change the volume unless you have a handset that can… unfortunately.
