Wireless Home Phone
  • 10 April 2019
  • 195 views
I am looking to add a home phone hub but i want to keep my existing phone number...how do I go about it?
If you just want to add a line to your current account just log in and order it. Your current line in your account will be unaffected. Did you want to have a Koodo line number switch over to a wireless home phone line?
Or if you meant that you want to bring a number over from another company and use it on the home phone you would follow the steps here:
https://www.koodomobile.com/help/moving-your-phone-number
I am confused. Do I sign up for the WHP then try to get the number I have on my current home phone
In that case if you have a land line already follow the link that Allan posted.
Yes, if ordering online sign up for it, then port the number over.
If you're doing it in store, they will port the number over for you right there.
