Wireless Home Phone
  • 5 February 2019
  • WHP
  • 1 reply
  • 28 views
Hi Everyone,
My wireless home hub won't stop "flashing" - notifying me that there is a voicemail. This, in turn, causes the phone that it is attached to notify me that there is a voicemail. Problem is, there is no voicemail. I have logged in to my phone inbox and it says that there are no messages. For good measure, I have also clicked "delete all" - just in case, but no luck.
I have unplugged/turned off both the phone and the hub on several different occasions - the voicemail notification goes away for about 5 minutes, and then comes back. IT IS DRIVING ME CRAZY!
Help? Suggestions? Has anyone else had this happen?
1 reply
Try calling your home phone and leave a message. Then listen to it and delete it. This might make the notification go away.
