WHP does the international long distance saver add-on work for home phone?
  • 9 September 2021
  • 2 replies
  • 148 views
Trying to determine if the international long distance saver add-on ($3/month) will help reduce the long distance costs on the home phone.
Also, I wondering do I need to purchased the add-on separately for each ofmy mobile numbers (2)?
Best answer by Dennis 9 September 2021, 22:44
In your self serve, if you go into your home phone line, you can click on add-ons for the international long distance saver.  That will help reduce your long distance costs.
And no you do not need to add the add-on on your other mobile lines for the international long distance saver to work on your wireless home phone.
Thank you Dennis
