The sim card dosent fit in my home hub
  • 15 July 2019
  • 3 replies
  • 149 views
Just received my home hub today. I tried putting in the micro sim card but it dosent fit! the cover wont hold it in either
The hub takes a micro sim according to the Quick Start guide. Your sim should come with tri-cut perforations so that you can pop out the sim in 3 sizes, Normal, Micro and Nano. You want the middle size
if you're visual!
Put it in and then grab a pen or something and push it down until it clicks. (Pen or something equivalent works best as it needs to push down quite a ways).
