Signal has disappeared on koodo hub
After having my Koodo hub for 3 years in the same spot it suddenly no longer has signal.
Any idea how to fix this…..
Best answer by MilkyWay 9 June 2021, 18:21
Did you reset the phone hub?
In case you need it, you can find the user guide on this page: https://www.koodomobile.com/en/help/101-koodo-wireless-home-phone
Also, you can try to move the hub in a different place and test.
