Koodo wireless phone offer
  • 28 August 2017
  • 8 replies
  • 30 views
How do wireless phones compare to cordless phones? I have heard that the latter are worse than cell phones for radiation output..
You use your own landline phone, no radiation involved 🙂
Oh, thanks--so the modem-like gizmo doesn't emit anything?
Emits exactly what a cellphone does, as long as your not putting your face to it for extended period of time your fine.
Would headphones attached to the phone solve the problem during long chats?
Honestly, I'd be more worried about the microwave than that unit, Karen. I'd say you're safe 🙂
Thanks! I'm one of those weirdos who doesn't have a microwave
Ok, put in another way: those cell transmission waves are in the air, whether we trust them or not - there is no escape. All that unit does is pick up those waves. It doesn't transmit any... because in order to make or receive the call, you will have to physically plug in your home phone wire.
If you use a home phone now, plugging it in the wall or plugging it in the unit makes NO difference safety wise.
Thank you for making it so clear that even I can understand, Sophia--much appreciated.
