I have a wireless home phone hub and a couple days ago my phone doesn't ring when someone calls
  • 1 October 2017
  • 3 replies
  • 28 views
(empty)
Did you check the phone that you are using it with for ring and volume?
Yes the phone is working the ringer and volume is turned up
Yes the phone is working the ringer and volume is turned upHave you tried turning the device off, then on again, or any of the other troubleshooting steps in the manual?
