I have a Koodo home phone and I have forgotten the number to enter to retrieve my messages. I know my password but not the code to get to where I enter the password
Best answer by Dinh
You meant the voicemail passcode to retrieve the voicemail message? If you forgot it, you can use your Koodo device access the voicemail and enter any 4 digits. After that it will give you the option to reset it.
“ You can reset your password by accessing your voicemail, then entering any random 4 digits when asked to key in your password. This will give you the option to request a password reset.” https://www.koodomobile.com/en/help/voicemail
If that doesn’t help, you will have to contact Koodo directly and ask a rep to assist.
