home phone
  • 28 December 2018
  • 2 replies
  • 116 views
how long after changing my home phone number to my old number will it take for phone to work
Best answer by Timo Tuokkola 28 December 2018, 23:36
If you're porting over a landline number it will take 2-3 business days for you to begin receiving incoming calls on the wireless home phone. (outgoing calls will work right away). In the meantime incoming calls will still come to the original landline connection so leave a phone plugged in.
If, on the other hand, the number you are bringing to koodo happens to be a cell number, the port should complete within hours.
When porting in a number for wireless home phone it could take up to 3 days before the port is completed. Hopefully it doesn't take that long for you.
