Feedback
can I take my wireless home phone to my cottage | Koodo Community
(empty)
Yes as long as you get cell reception it will work...it will even work on back up battery for awhile so you could use it in the car if you wanted.
Yes as long as you get cell reception it will work...it will even work on back up battery for awh...The only exception being if you have service or not. The home phone can go anywhere but will only work where Koodo's services are available.
