Broken home phone device
  • 6 January 2021
  • 83 views
The Home phone hub provided by Koodo is no longer working- the antenna is falling off - how can i get it replaced
Best answer by rikkster 7 January 2021, 09:03
If you have the ZTE model WF721 home phone (the label is on the underside of the unit) you can get a replacement antenna on eBay. The thin needle part is part of the antenna.
ZTE WF721 Wi-Fi Home Phone Antenna
Fall off how? They tend to Ge tloose easily. Can you not screw it tight again?
When did you get the hub?
The hub is about 3 years old - and it cannot be screwed in - it is a thin needle part that goes into the part that gets screwed in - the antenna just fell sideways and fell of
Unfortunately at 3 years old, you may not have any other recourse and it would not be under warranty anymore
