wifi calling
  • 28 January 2022
  • 2 replies
  • 29 views
I'm in Costa rica and unable to set up wifi calling. Although there are Telus towers here my roaming won't connect. What else can I do to be able to set up calling?
https://www.koodomobile.com/en/help/wifi-calling
Telus towers? In Costa Rica? There is no Telus network in Costa Rica. You won't be able to connect to WiFi because you are out of country. Maybe if it's setup already and you use a VPN?
So you're also not able to roam? Did you enable easy roam? Check in self-serve that you have “international voice roaming” and “international data roaming” added in add-ons?
