Why are Koodo Callbacks going to voice mail?
  • 18 October 2021
  • 3 replies
  • 148 views
Why are my callbacks from Koodo going directly to voicemail?
Best answer by Goran 18 October 2021, 02:34
Check your blocked numbers list. It has happened for some here as the reason why calls from Koodo went straight to voicemail.
@Wennelland There could be a number of reasons in addition to what Goran mentioned.  If your phone is on ‘do not disturb’ mode or if you are in a weak coverage area that could explain it too. I know, when I’m the basement of my house, half the calls go to voicemail because I have only have 1 bar coverage in certain places.
Did you have a question we could answer here?
 Thanks for your replies …
Evidently, at some unknown time, the Koodo number was blocked.  I’ve now corrected it, thanks.
