VoLTE Iphone
Hi,
I got an iPhone 13 and
VoLTE option is missing in settings,
I am looking in right options, and I have another phone with Koodo connection has the same issue
Both are on iOS 15.2
please suggest
Do you have the Koodo VoLTE Access add-on when you check “My add-ons” in Self Serve?
Thanks for the reply,
i just checked, it’s enabled.
Do you see a Wi-Fi Calling toggle switch? Have you tried to enable Wi-Fi Calling?
When Wi-Fi Calling is enabled, VoLTE should automatically activate.
I  managed to delete volte from my addons, thinking i might reset the volte status for my connection, now i can’t readd that
On your iPhone, do you see a Wi-Fi Calling toggle switch?
Settings > Phone > Wi-Fi Calling - tap the toggle switch to turn on.
I tried that too,
it ask me to enter my address etc, i did enter, and when i press continue, it takes me to same step 1 of 3,
I tried that too,
I’ve flagged a rep. The rep should be able to add the VoLTE access add-on back onto your Self Serve account. Since it’s after hours, the rep will likely respond tomorrow morning.
Thanks a lot, will see tomorrow
@Simranedm We have added  the VoLTE access back on to your account, we also verified and both lines have it. :)
Still same. Just shows lte and 3g.
WiFi calling in on though.
Have you tried restarting your iPhone?
Yes I did restart the device
Did you purchase your iPhone 13 from Koodo?
I bought it from apple, and the second device xr was bought from Koodo. Same issue
I’ve flagged a rep to take a closer look. There might be something on their end that needs to be activated for VoLTE to work.
Hi @Simranedm
Have you tried resetting the network settings in the phone settings?
I just did. No change
Thanks for checking!
In this case, we recommend to schedule a call back with our virtual assist, using the steps here:
 so a tech agent can look into it further.
