voicemail number not set notification wont stop
  • 5 January 2022
  • 1 reply
  • 15 views
When I get a new voicemail a notification pops up that says "voicemail number not set". My voicemail works fine when I call it. When I go into the notification it asks to set the voicemail number and when I type in my number it says I can't change it.
1 reply
The voicemail access number is different from your phone number though. Normally, It should be setup automatically by Koodo.
Anyway, have you tried to reset network settings of the phone and see if that can help?
