text messages
  • 15 January 2022
  • 1 reply
  • 18 views
I have 4 phones with kodoo can I get to see what text on any of my cell's from just one phone
1 reply
Koodo doesn’t offer the text forwarding services, so you can’t do it with Koodo account.
However, if you are using iphone, you can forwarding text between iphone using the same icloud account. Android also has some app in their Appstore. Make sure you check privacy settings of those apps before you use.
