Samsung a32 4G Network Compatibility
  • 22 September 2022
  • 3 replies
  • 21 views
Hello,
I would like to buy Samsung Galaxy A32 4G Volte Quad Camera Débloqué 128 Go LTE 6,4" Version internationale SM-A325M/DS Bleu and could someone me help with the compatibility of this phone with Koodo network.
Here is the the frequency from the description of the phone
2G GSM 850/900/S1800/1900, 3G UMTS B1(2100), B2(1900), B5(850), B8(900), 4G LTE B1(2100), B2(1900), B3(1800), B5(850), B7(2600), B8(900), B20(800), B28(700), B38(2600), B40(2300), B41(2500) - Dual SIM
I see that B4 is not supported. Does it is the issue and I should chose another model.
Thank you very much!
No that phone doesn’t fully compatible with Koodo. You might have some signal depending on the location but not reliable.
If you want to use features VoLTE, VoWifi with Koodo, you should get Canadian models of the devices.
Hello,
You will be able to use the device on the Koodo network, but you will have a better signal if you choose a device with more compatible LTE frequency bands.
Thank you, guys. I’ll seek the Canadian version. Have a good rest of the day!
