My Koodo mobile reception is VERY poor (typically -118 dbm or worse) at my home inside my house. The people I'm talking with are always complaining that my voice is "choppy" with periods of missed phases or dead spells. I am constantly saying "can you hear me now".
Sometimes the slightest movement on my part causes a dead spell. I can always hear them perfectly. This happens with many different people ... and it is ALWAYS my talking that is interrupted or dropped. Sometimes the call is dropped and has to be reinstated.
I have WIFI calling enabled and when the call is via WIFI there is not an issue. However, it seldom uses WIFI even though it should always be invoked due to the pitiful cell reception inside my house. Is there a way that I can force it to use WIFI calling? How does the system "decide" which path to use for a call? The algorithm for this decision must be VERY inadequate.
If a viable solution is not available I will have to look at other mobile providers since my current situation is so frustrating and embarrassing.
Thanks for your help. :)
