No VoLTE on Pixel 6?
  • 15 November 2022
  • 14 replies
  • 142 views
To my dismay I just received an SMS from Koodo: the one that says (I paraphrase):  Hey btw you are currently using a 3G phone and our US partners are moving on to VoLTE, you won't be able to roam in the US, etc.  I have a pixel 6 (bought from the Google store) I don't see why on Earth VoLTE wouldn't be enabled for me with Koodo. What's going on?
Do you have the add-on “Koodo VoLTE Access” in your self-serve? It needs to be added to be able to enable VoLTE.
Just checked "manage add-ons / add-ons available for you" in my Koodo self-serve: no mention of VoLTE access!
Before panic sets in, check out your handset compatibility with Koodo’s major roaming partner in the US:
https://www.t-mobile.com/resources/bring-your-own-phone#imeiextender
"This device is fully compatible with T-Mobile’s network technology"
Let me flag a rep so he/she could look into your account to make sure you had the VoLTE access add-on in your plan.
@fdmamen  We have added the VoLTE add-on to your account,  You can now finish activating it on your device.
Settings > Network & Internet > Mobile networkPreferred network type > Select LTE (recommended)
Seems to work now! I was even able to activate VoWifi! Thanks
I am having the exact same issue. Does a rep need to add VoLTE add-on?
Are you a postpaid customer? Also was there any error when you tried to activate wifi calling?
Yes and yes!
Yes and yes!
Let me flag a rep. In another post you said you and your wife had the same issues? I assumed both of you are on the same account?
She has a seperate account let me get her to post here
Yes hi please fix this for me also
Hi @Cortez @JBrain
We have added the VoLTE feature to your line, please restart your devices and let us know if it works.
