how to access my voicemail from overseas?
  • 15 November 2022
  • 2 replies
  • 30 views
I’m travelling.  How do I access my voicemail?
From your phone yo u don’t without paying the pay-per-use or easy roam rates. But you can access your voicemail from another phone. I’d setup a VoIP Canadian number with your choice of service. Many have free calling or very cheap calling. I don’t endorse any but I personally use Fongo.  Then you can reference this here to access it:
i can't access my voicemail, it keeps asking for a mailbox number | Koodo Community (koodomobile.com)
Make sure to also check for your access number. it’s linked in the above thread. As it says, be sure topress * once the VM goes. Let us know if it doesn’t work.
Hi Goran.
Thanks for the complicated response…   You could have said:
1- From any phone line other than your Koodo line, call your own number
2- You won’t hear it ring (of course), but as soon as you hear your voicemail message, type *
3- Entre your password at the prompt.
That’s it!
But thank you!
