Hi there! I am running a Sony Xperia XZ2 - while I am able to make and receive calls, and connect to mobile data (at speeds maxing out at only about 10Mbps), I am unable to send (and likely receive) MMS text messages. When attempting, I see the message “MMS is not available on this network.” I have tried all the APN settings, including those listed by Kodoo (which didn’t solve the problem) - https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone and elsewhere -
https://apn-canada.gishan.net/en/apn/koodo
https://www.4gapn.com/ca/en/koodo
https://techbiote.com/koodo-apn-settings/
Is there an updated, definitive set of network settings that I should be using, or is it possible there’s another reason I can’t do MMS (and that my data speed isn’t great)?
Thanks!
