calls bloqued
  • 3 February 2022
  • 4 replies
  • 32 views
I have a call block on my phone! Friends call me and they get this message. What can I do ?
thanks
Best answer by MilkyWay 4 February 2022, 06:44
What exactly does the message say?
It sounds like you may have the call control add-on on your line. This would give a message somewhere along the lines of "this person has call control enabled, to be connected please enter (insert number)"
The message my friend receive is the following: this person has a call block. If you want tour call to go through press 1.
some friends dont get this message. Its very strange
thank you
thank you
You may have enabled the call control feature on your Self-Serve account. Some of your friends may be on your Authorized List, which is why they do not need to press anything. Others that are not on the Authorized List will need to press the right button for the system to allow the call go through. Note that you can add up to 25 numbers to the list. https://www.koodomobile.com/en/help/call-control
Thank you. Problem solved
Your answer was very helpful
