Will my plan have to switch?
Looking to upgrade my phone. With the new tabs and plans, will I be able to keep my old plan if it stick with the small tab? If I want a medium tab will I have to switch my plan or will it just add on $5 a month for tab repayment?
Hi Katie, if your current plan is $30 or higher, you can choose between the Tab S and Tab M without changing your plan 🙂 If your current plan is below $30 you don't have to change it either, but you'll only qualify for the Tab S. Either way you can definitely get yourself a new phone without being forced to upgrade your plan!
Sweet, thanks! It was the only deciding factor in getting my new phone!
Just out of curiosity, what phone are you looking at getting?
S4 mini
If expandable memory isn't a problem, I recommend either the moto g for free on tab S or the nexus 5 for 100 on tab M. These are just suggestions, the final decision is up to you 🙂
My last phone was Samsung so I wanted to go with a Samsung so it stayed pretty close to the same way to work my phone but thanks for the idea! I also like the small phone fits better i my small hands!
