When I go to switch my plan, it gives me more options than it should. Am I going to get charged?
I have a tab large, and I used to have a tab large plan that said "Tab Lrg" in the front of the name but when I went to switch my tab plan, I had more options than it gives you for tab large when you're not signed in.. I selected one of the options that wasn't listed as a tab large, and in the name for the plan it wasn't listed as it either.. Will I get charged?
Hello Sana, If you succeeded in making the change successfully, then there will be no problem! But are you sure it's not a tab L plan?
What is the name of that plan?
Do you still have a tab remaining?
