I have a TAB S...with an existing plan....To upgrade my phone I need to lost my plan?
I want to upgrade to a S7 edge...I have an existing plan and a TAB S...
To get the S7 edge (available on line only), the system will force me to lose my existing plan...
Best answer by Chadwick 3 May 2016, 17:55
You do not have to change your plan as long as your upgrading to the same tab structure( normal tab or the large tab) If you have normal tab. yu will need to pay $644 to keep the same plan.
1 reply
