help me
Will I get charged for a toll free call when I am out of country
Best answer by MilkyWay 9 June 2021, 18:44
Yes. It is only toll free if you are calling within Canada.
 If you are out of country and use any cell service,  it will be roaming. And you get charged for using it.
You can attempt to sign up for a Canadian VoIP service for free and use data to place a call if you need to.
Keep in mind with your Koodo line you have the option of easy roam or pay per use.
