Will I billed for changing my number
  • 13 February 2013
  • 8 replies
  • 18 views
I read somewhere that if you use self serve to change your phone number its free. Is this true? I wont be billed if I change my number through self serve?
Yup, you don't have to worry.
Userlevel 3
Decided to change your number after all? Have you possibly tried blocking text using the following steps? http://helpblog.blackberry.com/2011/11/blackberry-message-block/
Decided to change your number after all? Have you possibly tried blocking text using the followin...Thank you for showing me this. I will give it a try. The only people I want contacting me are on my contact list anyway. So thanks.
Decided to change your number after all? Have you possibly tried blocking text using the followin...Keep us updated with the status of your problem!
Decided to change your number after all? Have you possibly tried blocking text using the followin...I don't know how change my number help
Decided to change your number after all? Have you possibly tried blocking text using the followin...Log into self serve > scroll down the page and click " Change phone number > option 1 and follow the instructions
Decided to change your number after all? Have you possibly tried blocking text using the followin...I can't find anywhere on my koodo self serve to change my phone number.
Decided to change your number after all? Have you possibly tried blocking text using the followin...You have to use self serve account. You can't change your phone number through app.
