WHY, is my bill 5 times my usual amount?
If you look on page 3 of your bill it will give a breakdown of what your charges were. Likely you had some huge overages or roaming possibly.
Hey Myra,
Have you tried to check your invoice online as Goran suggested? Please note that you can also dial #123 to check your usage summary via the automated system. You will be able to confirm your account balance and if there's any past due amount from a previous invoice, the system will indicate that as well.
Thanks.
