web site awkward and unusable
I can't give praise for your web site. It is awkward to use and not very functional. I recommend that you try using from a customers viewpoint.I particularly find viewing my usage history barely usable.
Why don't you use their app for usage? That way you can see it on the go instead of waiting to get to computer. Just curious.
Can't say I agree with you. I've used it from the customer's viewpoint and found everything logically arranged and easy to use.
What would you suggest should be better, Brad?
Userlevel 4
I find it works very well.
