Upgraded plan to get 1000 international minutes
I saw the deal today that if I upgraded my cellphone plan, there is a limited offer of 1000 international minutes. I did the upgrade from a $20 plan to $50  through self-serve online. But I don't see it listed as a feature in my plan description. Do I have to go to a kiosk to get this fix?
Thanks.
Check your add ons, it may be listed there. Also check your plan description.
I was told by our Koodo liaison that the international minutes are only for new activations and upgrades. So a simple plan change does not include that part of the promo. I also changed my plan and thought I would be getting them, but didn't.
Chadwick wrote:
I was told by our Koodo liaison that the international minutes are only for new activations and u...
I see. Thanks for the reply. I should think that there should be proper fine print for this on the website somewhere. But I guess not.
[i]"I should think that there should be proper fine print for this on the website somewhere."
This has been suggested and hopefully will be seen in future offerings!
And by upgrade, they mean buying a new phone!
Thanks for your reply!
