Unable to log in to self serve
  • 13 February 2015
  • 7 replies
  • 52 views
I am trying to log in to prepaid self serve. Unfortunately, I forgot my password. Whenever I type my email and press 'Forgot password' it says: 'Unable to verify your email'. What's wrong?
Is this your first time using self serve or have you been able to use it prior to this?
Is this your first time using self serve or have you been able to use it prior to this?I've used it before, but forgot my password and ever since then it keeps saying that my email is not verified.
first time
first time You may have input your email address incorrectly when setting up your self serve account in the first place. Did you recieve any verification emails or anything from Koodo while setting up the self serve account? If that's the case that the email was set up incorrectly then you may have to call customer service during business hours and have them fix the issue.
first time Ok, I guess I will give them a call. Thank-you
yeah I guess that is it thank you
Also make sure you are using the right self serve. The prepaid self serve is different from the postpaid self serve https://prepaidselfserve.koodomobile.com/ https://www.koodomobile.com/sso/UI/Login?realm=koodo&locale=en&goto=aHR0cHM6Ly9zZWN1cmUua29vZG9tb2JpbGUuY29tOjQ0My9hY2NvdW50L215S29vZG8ucG9ydGFs&encoded=true
