Unable to access settings for Self Serve
Whenever i try to access my self serve settings, it keeps redirecting me and goes in a circle for a few refreshes, then redirects back to the simple self serve.  Basically only gives me a few options.  Unlike a couple of months ago i had access to more settings in my account. I only have access to View Usage, View Tab Balance, View Rate plan.
Are you using the self serve app? it's been disabled
No, using the website.
What are you trying to do in Self Serve?
