TRYING TO CHANGE MY PLAN
trying to change from my plan now to the 37.00 plan that has data.
You can change your plan on self-serve under "Plan and Add-ons". If you already changed your plan this billing cycle, you will have to wait until your next billing cycle to change your plan.
Userlevel 2
Ahmad wrote:
You can change your plan on self-serve under "Plan and Add-ons". If you already changed your plan...
can't you change your plan every 14 days?
Unless it was changed recently (within the last month or two), then I don't think
Hi Arika, customers can change their plan once per billing cycle. Thank you!
You could also use the self serve app on your phone.
