trouble with connecting
i cannt connect to network and i cant check the usage
Userlevel 3
More information please. Are you trying to access the Koodo app?Or the self serve online?You mention cannot connect to network have you tried pulling out the battery and sim card?airplane mode in settings?By turning it on and off
What phone do you have?
Nexus5
So texts, calls, and internet all dont work? Did you make sure your have 3G/4G/LTE on? Are you on prepaid or a monthly plan?
yup i use another sim card its ok but my koodo card doesnt work
Did you recently activate? It could be an issue with the card or something happened during the activation
yup i download one app and the card is dead
Go to Koodo and see if a new card fixes the issue
