Transfer number problem
Question: I've already had a phone with koodo monthly service. Then I use a koodo tab to buy a new phone, which is Nexus 5. I'd like to transfer my original number to the new one, but it fails. How can I solve that? I really don't want to change my number. Thanks!
You can just pop in your current sim if it's a micro sim or if your sim is not the right size, you can get one for 10. Then sign into self serve> mobile phone>upgrade mobile phone> enter the sim # and done! you will also keep the same number 🙂
Daniel Kim wrote:
You can just pop in your current sim if it's a micro sim or if your sim is not the right size, yo...
Thanks, I inserted an image below.
Thanks for the reply. But when I use tab to buy a new phone, it always accompanies a new micro sim, which is inevitable I guess. Then the new mirco sim carries my tab plan, and my original number carries another. So it's not simply number transfer. I also need to swap the plans. That's what I got during the online shopping.
Walden Han wrote:
Thanks for the reply. But when I use tab to buy a new phone, it always accompanies a new micro si...
Did you login to your self serve to do online shopping?
yep, I did, double-checked. But it still required me to type in my name and number.
Are you choosing a plan when you say you want to buy the phone?
Yes. I am using a monthly plan now and chose a new plan for the new phone. Should I shut down my old plan?
That's your problem. If you add a plan to the cart the system thinks you want to add a new line. Just add the phone and skip directly to checkout.
En...I've tried that. If I don't add a plan, I am not allowed to use the tab. The phone will be fully charged at the last step of shopping. I attach an image below.
Is your current tab balance positive or negative? Do you currently receive the no tab discount?
Receiving no tab discount.
That's probably why the system won't let you use the negative tab on your line.
Since the Easter is over, I'd like to go to the store to find the answer. Thanks so much!
