Transfer number from one phone to another
Question I need to change a number from one phone to another, both phones are the same model Samsung sch-u450, is this possible and how. Thanks Jeff
Best answer by Jonathan I 13 February 2014, 03:31
You can do this in Self Serve by going to the Mobile Phone tab and then upgrade/swap phone. When it asks if your new phone uses a SIM card, say no, and follow the instructions. You'll also need to NAM program the "new" u450 (basically changing the phone # registered on the device) to yours. Try this: http://agilx.net/nam-programming?sobi2Task=sobi2Details&catid=46&sobi2Id=319
1 reply
