Site error while changing plan!
A picture's worth a thousand words!
Have you done the usual clearing cache/cookies, using it on correct web browser?
Yeah I just did because my Koodo was stuck on the BC... I'll try another browser
Happening to me too and has been for the past at least few days.
Working on IE, not on chrome!
Self Serve is not optimized for Chrome. Only IE8+ & FireFox3
Works best on Chrome. I'm not sure where you get it's not optimized. 🙂
Koodo has stated it works best in ie and isn't optimized for chrome or ff
It is optimized for FireFox 3. Koodo has stated this.
If you are talking about the message on the bottom in self serve, I bet you they just forgot about. 🙂 It must have been there from the beginning and no one bothered to check.
A quick update on this folks! As always, we took your feedback to heart and talked to some of our IT teams. They performed a "recycle" (don't ask me what that is) and they claim the issue should be temproraly fixed with a full fix coming in October. Thanks again for the heads up!
Bernard wrote:
A quick update on this folks! As always, we took your feedback to heart and talked to some of our...
Thanks for the update!
