Short Codes (Star & Pound)
What are the "Short Codes (often referred to as Star and Pound Codes) that can be used on Koodo to find out how many minutes you've used or how much your account balance is?
I don't think koodo has these however if you use the Koodo App, the data it uses is free. You could check that way.
Hi Robin, dial *611 from your phone 🙂 You can find out your account balance, airtime summary, make payments and even reset your voicemail password! Chad is right, the Koodo app is also very useful. You'll find more info about it on this link: http://koo.do/Zr37lk. Thank you! ________________________ If you see a good answer, give it a star.
