Self Serve not displaying
Whenever I try to use Self Serve I cannot get it to display properly, I've tried Chrome and MS Edge with the same results when I select Self Service and any of the Dropdown choices: Usage, Tab, My Profile etc... Here's a screenshot of what I get, Adblock isn't on etc...
Can you try again in an incognito / private tab and get back to us?
Same deal
@Matthew, i think you might be using a username (email)  associated with an old deactivated account of yours. Try the other one with gmail address.
Bernard wrote:
@Matthew, i think you might be using a username (email)  associated with an old deact...
Winner winner chicken dinner! Thanks, not sure why that old email still lets me in to some sort of limbo world haha
Yeah, that is something I will have the team look into Matthew!
I have the same problem.
I once had an active line, then disconnected.  I recently joined back in and get the problem.  What should I do?
Send Koodo a message via Facebook and they can get your sorted out. It just sounds like you have 2 accounts on one email.
