Self Serve - Location specific plans not found (SK Specific)
I have recently signed up for the talk plan about a month ago and want to change to the SK $48 dollar plan (5 Gig with unlimited calling) but when I log in and select change plan, I just get a generic list.
Seems like the plan is not selectable through self serve.  Any ideas?
If you reside in SK, you can call in and ask for that plan or similar ones to be applied.
Would I be charged the $10?
Contact us on Facebook direct messaging for your request Brandon.
No you won't be charged as its something you can't do yourself through self serve, your only charged for getting them to do something you can do yourself through self serve.
You are going to wait long on the phone. Make it easy for your self Brandon. Use Facebook to contact us.
Be warned that if you do not have a SK number and do no reside in SK that you will not be able to switch to the SK region plan
