Samsung Galaxy Ace (Add-on question)
  • 16 July 2012
  • 1 reply
  • 3 views
My Samsung Galaxy Ace originally came with a $25 talk and unlimited text plan. I just added on the 100mb data. When will this change come in effect and is there anything I am going to have to do such as go and enable the data that would add extra charges if i didn't have it on my plan.
Best answer by Ahmad 17 July 2012, 14:13
It comes into effect within 15 minutes of you adding it, if not right away. Your data should already be enabled unless you disabled it.
1 reply
