Registering on self serve but asking for driver's license number?
I want to register on self serve but they are asking for driver's license number, the problem is I don't have driver's license. How can I register without driver's license number?
What ID did you provide when you signed up for service? Try entering that number.
Userlevel 2
Hey Shei, were you able to get this resolved? ________________________ If you see a good answer, give it a star.
Thanks. A customer service agent of Koodo helped me about it. 🙂
call customer service they will send you a profile confirmation link right to your e-mail! and they will assist you with 1st time setup with self serve and give you the mini tour!
I have same problem. What should I do?
It depends on what ID you gave them. For example, If you gave them a provincial ID card, try entering that ID number
I tried whatever ID that I give them, but it says that : The information you have entered is incorrect. For security purposes, your account will be temporarily locked if you fail to enter the correct account information on your next attempt.
Give Koodo a call and they can set you up. *611 on your cell or 1-866-995-6636
