referrals
  • 20 April 2020
  • 2 replies
  • 108 views
How do I make the referral work? I tried signing my husband up with my referral code, and it says it’s invalid?! Is it just a scam that doesn’t really work, and you get so frustrated with the process, that you just give up and don’t use the referral code and then miss out on free money?!! It shouldn’t be that hard!!
Did your husband submit his info (step 2) prior to signing up?
https://choosehappy.koodomobile.com/refer/mb/
Are you trying to do a prepaid or postpaid referral? Prepaid accounts have referral codes, postpaid ones have links that you send.
Prepaid can only refer prepaid.
Postpaid can only refer postpaid.
