purchased wrong card
  • 31 March 2015
  • 1 reply
  • 356 views
hi i purchased a 100mins on my koodo prepaid can u swtich it to 500mins instead?
Best answer by Sophia 31 March 2015, 16:37
Hi David, You can call 611, and explain the situation. They'll probably change it for you - easiest would be if you added the funds beforehand so all they need to do is make the swap 🙂
1 reply
