printing airtime history with numbers
How can I print the airtime history with the phone number details. When I press control p it takes out the column named details with the phone number
You could take a screenshot, that is probably easiest. Your PDF invoice would give a detailed view of your airtime with numbers as well.
Sophia wrote:
You could take a screenshot, that is probably easiest. Your PDF invoice would give a detailed vie...
I second the pdf invoice printing
There is a neat piece of software 'Cute-PDF' which allows you to print to a PDF file as though it were a printer. It allows you to create virtual paper sizes larger than the page Koodo publishes. This gets around the CTRL-P issue.
You could also cut and paste to a Word document, and manipulate from there.
Is there a need to have a paper copy of your invoice? You could save it to a disk for future retrieval.
David wrote:
There is a neat piece of software 'Cute-PDF' which allows you to print to a PDF file as though it...
If using a Windows 10 PC, you can print to PDFs without 3rd party software.
Wait.... does OP have problems opening pdf?
