Plan Changed BY Accident
I was able to swtich to the 10gb plan for $60 during the week. I wanted to add a second line today as a.gift.
After checking out, I realized they made the change to my current line and I did not add a new line.
What can I do?
I will try calling Koodo in the morning but I am worried I lost the $60 plan for good.
Best answer by Mayumi 23 December 2017, 15:15
"After checking out, I realized they made the change to my current line ..."
 - How did you try add a 2nd line?  Through online by your self(After checking out?), or store rep (they made the change to ..) ?
Do you still see your current $60 plan?  If not, it's likely gone from system since the plan was promo plan...  You can try to contact them and ask if they can get it back, but there is no guaranty.
1 reply
