Plan
Be able adjust your text and talk after you use it for acouple of months to see what you use the most.
Hi,Sue. You can check your airtime/text usage when you log into self serve. Also you can change your plan any time you like (once per billing cycle. 😛 {Correct me if I read your post wrong} 🙂
Mayumi wrote:
Hi,Sue. You can check your airtime/text usage when you log into self serve. Also you can change...
May Sue is thinking of changing to new Plan after she tried her existing Plan, any customer can change his Plan once a month if he wants to.
Hi Sue, You can adjust your plan once a month using Self Serve. 🙂 https://secure.koodomobile.com/account/Registration.portal
