Password Reset Email is not sent
  • 26 August 2020
  • 8 replies
  • 211 views
I tried to reset password.
I clicked “Forgot?” besid password at Log-in site.
Then, I wrote my email and my last name.
The website said,”A password reset has already been requested for this account. If you didn't receive a password reset email, check your spam or junk folders”
So, I tried to find email that they told.
I tried to find at Junk folders and also other folders.
But, I didn’t get any email from Koodo, although I waited for one day.
Is there solution to reset my password?
Are you sure your email was entered correctly or is the correct email for your self serve?
Maybe try the Forgot Email link if you are not getting the forgot password email.
Have you ever successfully logged in to your self serve account before?
Yes, If I didn’t write my email address correctly, they said “The information you entered doesn't match our records. Do you use a different email to log in? Forgot your email?
So, I wrote correct email address.
Also, I successfully logged in my email account before.
I've flagged this for a ep to look into. This is odd indeed.
I used koodo assist and It help my problem thank you!
Out of curiosity what did you say in koodo assist to get it to fix things for you?
I wrote that I lost password and then I put my email address.
then, koodo assist said It send password reset email in 5 minute.
so, I got email. I reset my koodo account password.
Userlevel 4
So you were able to reset your password and access your Self-Serve account in the end? Please keep us posted and let us know if you need more help, we’d be glad to assist you asap.
