not able to switch my plan
  • 29 April 2020
  • 2 replies
  • 124 views
Self serve is not letting me change my plan! I need to switch to get unlimited minutes for work. I keep getting an “oops something went wrong” message every time I try. Help!
Best answer by Timo Tuokkola 29 April 2020, 16:33
If the only thing you want to do is increase the minutes, you can get an add on for $2 a month to upgrade your existing plan to unlimited minutes. Just text ‘MOREMIN' to 7780. Not exactly the same, but it may get you what you need.
Oh it worked!! Thanks so much you are a life saver!
